1 - 1 of 1 Posts
I have the Bell 6131 HD receiver in my setup. According the the manual when you hit the button it will cycle through: normal / zoom / stretch / zoom-stretch / etc for HD programming, and when you hit the it changes for SD programming.
cycles fine, I have my A/V receiver & TV set to normal and when on HD and the sat receiver is on normal it fills the screen perfectly.
The problem is that I am not able to change the SD zoom / stretch options. The menu to change these options pops up but it just sits at normal... almost as if normal was the only option. But then if I push it will change the zoom/stretch for HD channels however Im watching an SD channel.
Any idea what the problem could be? Its almost as if my receiver thinks both the HD & SD channels are all HD and it cant distinguish between them.
1 - 1 of 1 Posts
