Hi,
I have successfully upgraded my Benq 1080ST from Firmware Version 1.03 to 1.05, all went fine but I think Benq has increased the speed with which the fans are running by default, with 1.03 I was running the projector in "High altitude" mode and the noise was still OK... If I now with 1.05 run the High alt modus it sounds like an airbus is starting in my room and also in normal mode its more noise than before in "ha" mode.... As i didnt found any major improvements and the displayed temp. is more or less the same than before iam thinking about to downgrade the projector to 1.03 again.
Has anybody done this before ? Is it possible ? I know that you cant downgrade some devices (like the PS3) once you have upgraded to a newer firmware.
Thanks for the answers.
Cheers Vader...
Hi,
Cheers Vader...
