Status
Not open for further replies.
1 - 1 of 1 Posts
Well got all my lines ran today and now I find out that I am having an HDMI problem. I am using a DVI -> HDMI adapter(a good one) running straight from my Denon 1910 DVD to the PJ. Set the player to 720p output and fired it up. It worked fin for about 3 minutes then the picture started clipping out, with the message searching at the bottom. Every few seconds it will grab onto the picture and say 720p60 at the bottom showing the correct format.
Component seems to work fine the PJ only does it when using the HDMI jack.
Not sure if something is wrong with the equipment or if I just have a setting wrong, any ideas?
1 - 1 of 1 Posts
Status
