I usually use the DVI input from my DVD player (Denon 2910) but I'm trying to use component to access some other features. The problem is, the projector will not sync with component. I tried a cheap DVD player and it works fine. So far, the denon, zenith 318, and bravo d2 will not sync (quick flash of image every few seconds, split in two and distorted, then blank screen, then flash...etc) with component input. Just the cheapie works.
I thought it might be the cables but I used the same cables when connected to the cheap player.
Is it the projector or the DVI/component players?
Jeff
Jeff
