Status
Not open for further replies.
1 - 2 of 2 Posts
The 6100's fans are in the rear. Does anyone know how much clearance they require?
The 6100's brightness is 1500 ANSI lumens. Is this with the clear segment on or off?
Subjective observation: This PJ may not be designed for smaller rooms. To project a 75" diagonal image it must be 10'3" from the screen with the zoom wide open. Assuming the fans require 12-18" clearance, then it needs to be 11/12 feet from the screen for a 75" diagonal image.
I believe the manual says to mount about 19" away from any wall.
I have not been able to determine if the 'clear' segment can be turned off, or if that is what happens in economy mode. Regardless, I am sure the 1500 is on the brightest setting, which would not be economy.
The X1 will give you a larger image for the same amount of throw.
Billy
1 - 2 of 2 Posts
Status
