Thanks for the info Frank. I keep reading on these non-English sites that these puppies can handle HDR10+, but I've yet to see this in any official literature? I'm guessing it's a mistake. Anyone know?
That's what I thought. Thanks for the confirmation.No they can’t do HDR10+. Just HDR10 and HLG
The French reviewer Grégory suggested no more, he (correctly) wrote "HDR 10, HLG"
Can't help to think that it might be a smart move of BenQ to release both new models simultaneously.
As I expect demand for the HT3550 to be very high on release day, releasing the HT5550 simultaneously could take off some pressure of the HT3550 (but then again, I definitely prefer the HT5550 to be thoroughly checked and ready, before being released prematurely with bugs).
The HT5550 is only going to be sold through BenQ's dealer network. It is not going to see the wide retail release of the HT3550.
My bad, I should have written W5700 and W2700 as I'm not aware that this dealer network exclusivity applies here in Europe.
There is one little thing I do find annoying about the W5700 / HT5550 already now - BenQ highlights the black casing to reduce ambient light reflections on the casing, nevertheless features the green "power on" LED indicator on the projector's front side. :frown:
I doubt that LED will be bright enough to cause any concern. Who knows, maybe they’ll let you shut it off in the menu.![]()
I'm seeing 10' 5" to 16' 9" for a 106" diagonal on the 5700/5550.Have any of you math majors figured out how to guesstimate the range of this projector with its 1.6 zoom? My screen is 106" What would my short to long distances be? It's not on Proj Central yet.
Excellent. Looks like I will be close to the sweet spot at a little over 13 feet.I'm seeing 10' 5" to 16' 9" for a 106" diagonal on the 5700/5550.
FWIW the Optima UHD65 has a similar lens range (1.39-2.22) versus the 5700 (1.36-2.18) to get you close.
EDIT: I see the JVC UH-LX1 has the same range as the 5700 so any calculators that have this unit should give you what you need for distance.
According to the specs: 1.36 ~ 2.18 (1.6x)Have any of you math majors figured out how to guesstimate the range of this projector with its 1.6 zoom? My screen is 106" What would my short to long distances be? It's not on Proj Central yet.
With your familiarity, hopefully it, at least, does everything the 3550 does as a baseline.I will be getting some hands on time with this HT5550 at BenQ's HT3550/HT5550 launch even in NYC on the 21st. Anything you all would like me to test for you?
Awesome, thanks so much for the offer!I will be getting some hands on time with this HT5550 at BenQ's HT3550/HT5550 launch even in NYC on the 21st. Anything you all would like me to test for you?
