Hey guys,
I'm looking at either the Berkline 090s or 088s in a
4 seat side-by-side configuration - 14 feet back from a 106' screen...
I'm undecided as to whether I want straight edge or wedges...
The room is 16 feet wide.
How many feet do you usually allow for clearance on the sides of the seating between the edge of the seat and the side wall? Viewers will have to wall around the back of the couch since my entrance is in the rear, and i'll already have surrounds mounted at about 6' high on the side wall that come out a foot and a half....
You think 090's are going to be too big to use 4 seats? Should I look at the 88s instead....Part of me thinks the 090s are a better chair as far as comfort (i've only seen the 090s)...
