Originally posted by hvn4179
I should make myself clearer. If I have three regular seats, 6 arms total, and I want to reconfigure them in one continous row with the middle seat share the arm of its neighbor. It means I have to remove both arms off the middle seat. Is that possible? |
The Manual Release Button (a round push-in button) is located to the right side of the seat just below the cushion, it is not attached to the arm as with the electric versions.
The NEW and IMPROVED electric control is a much smaller toggle type controller mounted to the arm (The old version was a actual hand held remote that was recessed into the arm...pitiful looking!)
Now, with an armless 090 the manual button is located as usual below the seat cushion....I can then only assume this is where the "new" electric switch is located.
With THREE seats you have several options:
1.) Three individual 090's...each a separate unit, two arms each.
2.) Couch type combination: One unit w/ Right Arm..One unit Armless...one unit w/ Left Arm.
3.) Love Seat Combo: One unit w/ L Arm...One with Right Arm and one more with either Left OR Right Arm to place along side the Love Seat.
4.) Love Seat Combo and Single Seat. Same as above..except the third seat has BOTH Arms and can be placed together with Love Seat..or apart.
I did #3 on my rear riser....and four 090's with single arm/wedges for the front row seating. The rear seating accommodates a couple who may want to "snuggle". Also, when alone....I can stretch out on the Love Seat and just listen to music.
I did not opt for #2...as there is no cup-holder for the middle person.
I hope that helps?
Also. No. The arms are not removeable. Only the backs can be detached for transport.
