Hi.
I'm building a HTPC for a environment of 75% music (include future use of DVD-audio) and 25% movies.
I guess that the operation system will be the Windows XP pro.
The feature that the sound card must have:
24/192 7.1 output.
Minimum recording quality 24/96 or better (if possible more then 2 channel).
In/Out SPdif, if possible also in/out Toslink (optical).
ASIO 2 support.
Ability to connect a phono directly to the sound card.
Ability bypassing the windows kmixer.
Good Headphone output preamp (not so important vs the requirement above).
Since my receiver is the Pioneer Elite 47TX, does the RME DIGI96/8 PAD is not
a overkill in term of quality?.
If it possible, please post a link to a RMAA test result page.
Thank You.
J. Henkin
24/192 7.1 output.
ASIO 2 support.
Thank You.
J. Henkin
