Best antenna to get for OTA HD channels?
5167 Views 12 Replies 4 Participants Last post by  andyacecandy
I have the Samsung LN-T3253H hooked up to my wall. No digital cable or anything. I am in College Station, TX and use Suddenlink as my provider.
I have heard of some people getting more HD than me. Just wondering what the best antenna would be to get?
These outdoor ones... how does that work? How do I plug it into my TV if it is outside?
Sorry, I'm a newb at this stuff. I just wana pick up the most OTA HD channels I can
What about this Terk one?
Will I really pick up a lot more HD channels than I already am? Does it make the picture quality better too? Also, how do I see the % of signal I am currently picking up?
1 - 13 of 13 Posts
Is your zip code 77840? If so, antennaweb shows only 3 local digital stations in two different directions - one on VHF 12, the other 2 on UHF. Your local ABC and NBC stations are LP , low power, which are not likely to go digital until close to or in February, 2009.
Also, 77840 puts you around 88 miles from Houston and 90 miles from Austin which is deep fringe range if you can get those cities at all. For the more distant cities, you would need to go a roof top mount with long range VHF and UHF antennas. You connect the roof top antenna by running a RG-6 co-axial cable from the antenna into the house to your TV or ATSC tuner STB.
For antenna basics, check the OTA reception sticky in this forum. Also check http://www.hdtvprimer.com/ISSUES/erecting_antenna.html .
I like to steer people toward OTA reception, but in your case, you should look at what digital channels, either SD or HD, your local cable provider has to offer and what the cost is. The more remote rural areas dependent on low power or translator stations have to wait until the analog shutdown to get some or all of the major networks in digital OTA.
See less See more
so getting an antenna wont really get me that many more channels huh?
thanks for the answer. me and my roommate got new TVs both Samsungs and we want to get direct tv or upgrade to the digital cable package with suddenlink but the $$$ isn't fair to do because the 3rd roommate doesnt have an HDTV so making him pay would be wrong
i get all the local channels except FOX and NBC which kinda sucks oh well when I go home for holidays, ill see what i can get near houston
It is possible to get stations at 80 to 90 miles depending on the terrain and the elevation of your location. You should be in pretty flat country which helps. Something on the order of an AntennasDirect 91-XG for UHF and a Winegard YA6713 for upper VHF with a pre-amp and rotator on the roof can get stations at very long ranges. But we need some more information as your zip code and a description of your surrounding terrain. You can go to tvfool.com, enter your exact location and a height of 30' or 40' for a rooftop antenna and see what dBm signal strength levels it estimates for the digital stations.
But for the three closer digital stations, the less expensive non-amplified Terk HDTVi would probably work.
i am located in college station, texas
zip code 77840
its flat terrain houston is about 90 miles away
i get CBS, ABC, PBS, National Geographic, Starz Family, and some stupid local channels in HD. I have heard of some people in my area getting FOX too....
If an antenna can't get me anything more than it isnt worth it probably. So the question is, will I pick up anything from houston? probably not being so far away
See less See more
Are you in a house, apartment, or dorm?
An outside antenna might be worth looking in to.
im in a 2 story townhome, my rooms upstairs and i do have a balcony.....
should i just go buy one at best buy and see what i get then if i get nothing, just return it. if i get a lot, just return it and find it cheaper online? haha
You have the three close stations:
* yellow - uhf KBTX-DT 3.1 CBS BRYAN TX 98° 17.9 50
* yellow - vhf KAMU-DT 15.1 PBS COLLEGE STATION TX 312° 1.6 12
* red - uhf KYLE-DT 28.1 FOX BRYAN TX 306° 8.0 29
The Houston stations at some 87 miles would require a serious rooftop setup. Your mention of roommates suggests that you are renting or not planning to be there for a long time. If you want to keep it simple, you could try a Channel Master 4220 2 Bay bowtie or CM 4221 4 Bay on the balcony and see what you can get. Your close distance to the KAMU-DT PBS stations makes a pre-amp problematic. Or just get a basic tabletop VHF rabbit ear and UHF loop antenna for the Fox & CBS stations and go with cable for the rest.
See less See more
whoa...... i just scanned and picked up EVERY local channel
ABC, CBS, FOX, NBC, PBS, Starz family, National geographic.... all in HD
i dunno where this came from but im so happy right now
woooo
Must be some sort of cable system you are hooked up to. Some of those channels are not OTA.
weird i returned the antenna, came home.... and the new HD channels were gone!
how is this so.... they were there even though my antenna wasnt even hooked up to the TV. this is weird.... could it have somehow still been working even if it wasnt hooked up?
hmm...
Are you still connected to the cable system? Try a re-scan for digital QAM cable, not ATSC OTA. But don't expect Starz or Nat Geo HD to stay available as those channels are usually encrypted.
2
How do I scan just the QAM tuner? I have a samsung and I can only go to Auto Program. I have Suddenlink basic cable right through the wall...
It has STD, HRC, or IRC..... i did STD the day I got FOX and NBC
Now I dont get them
I'd rather have those 2 than starz and national geog
Do you get NBC, ABC, FOX, PBS, CBS in HD?
I scan for cable only.... I even went back and got the antenna today and plugged it in just the same way I had it the day I got all the channels haha but no luck
See less See more
1 - 13 of 13 Posts
