Dear all;
I really like your forums, I feel it is full of information.
I am currently installing some pipes in my new home theatre. I will have some high end equipment such as the Denon 3312. I need the best wires. The room dimensions is not so big (5x5 or so...). While installing the pipes I realized that after pulling the cables, one of the speakers would need around 27 meters of cable! I am also using aroun 1inch pipes.
I am trying to think out for other options, but I am running out of time since my wedding is on the 9th os September!
Lets say I couldn't find some 'constructional' work-around, in the worst case scenario, what kind of speaker cables (good ones) will deliver the sound in highest possible quality?
I am not so good with speaker cables, I have read a lot of information in some short time (however just theory). I need to know if this is possible, and if so, would I be able to install four of the suggested cable into the one inch pipe.
thanks in advance!
Note: someone told me that I should not buy any cable that is less than 12 gauge. I would appreciate if any one can point me out to a specific cable rather than all this technical wording (volts, amps, gauge) - it sometimes can feel chinese!
thanks in advance!
