Status
Not open for further replies.
1 - 3 of 3 Posts
I have mmc 7.5 installed and am using the video and audio filters. I have read that the Powerdvd xp audio filters are very good. Which one should I be using.
Damien
WinDVD is generally regarded as the most stable/compatible. Although I have been using PowerDVD's audio filter with great results. Cineplayers audio filters are terrible.
Mostly agreeing with MadChemist,
WinDVD is known for stability and compatibility but I think PowerDVD tends to get the nod for quality with a sacrifices in the other areas. I also personally use PowerDVD exclusively (might buy WinDVD 4 for the DPLII in a month or so.)
1 - 3 of 3 Posts
Status
