best audio format?
2904 Views 31 Replies 14 Participants Last post by  Elemental1
Ok, this is only SLIGHTLY off topic as I play all my music through my HTPC.
In regards to rips of audio CDs. I recently read that the WMA format is a much better format (than MP3), it is supposedly manages to get similar compression while not losing as much of the audio. I currently do my MP3s at 192 CBR. Will I get better sound out of a WMA. I had even thought of going with WAV format am not entirely sure I want to use that kind of space.
Yes I can hear a difference between an MP3 and an original CD both in my car ($5000 system) and at home ($4000 system). What you guys think?
1 - 20 of 32 Posts
Well...I use MP3 @ 320kbps and it's sweet with my Vista setup.
WMA might not be a bad format though.
See less See more
No. WMA only has a slight advantage at very low (e.g., 32-96 Kbps) bit rates. At 128 and above they are similar, and you lose compatibility with WMA. At 192, stick with MP3.
http://www.mp3-tech.org/tests/wma9/index.html
WAV is pointless, use lossless (e.g., FLAC) if you don't want any lossy compression. But worrying about such nuances in the car is totally silly.
Lossless is the best way to store your music, which format is best depends entirely on what programs/devices you want to use. Pick the lossless format that works with your desired software/hardware.
MP3 and WMA are both well supported so maybe he just wants somebody to pick the best format for him.
I'd say MP3....it's the most open standard.
If you open the settings in MICROSOFT media player, there is a neat little link that leads you to a site on MICROSOFT that exthols the virtue of the MICROSOFT WMA format.
http://www.microsoft.com/windows/win...userlocale=409
What I am doing is riping all my CDs to my hard drive, well most are already ripped but I am thinking of new CDs I buy. I own the CDs so if I want to go back and re-do it again at a better settings I can, but I hope to never HAVE to do this (lotta work). What brought this up is now that I have better speakers at home (B&W FMP5) I am convinced I can hear the difference between a MP3 and it's original and want to get the best out of both my car speakers and my home speakers. I have never considered WMA before (I mistrust any MS related media format-since the advent of DRM).
As far as Car goes, I most definately CAN tell the difference between a MP3 and an original. Now, granted, at 85mph that difference is lost in "road noise" but at red lights I am happy.
foobar2000 + abx then tell us if you can hear any differences
as others said:
FLAC for long time storage and plenty of space
MP3 for portables and limited space
Oops, just realized you also want to play them in your car. Then I would go with MP3.
If you use Microsoft's Media Player for ripping and play back (or MCE for playback). Then WMA Lossless is the easiest/best. Just rember to go into Tools/Options/Rip Music and select the "Windows Media Audio Lossless" format.
foobar2000 + ABX comparator plugin lets you select 2 tracks and switch between them while playing and see if you can pick which one is the mp3/lossy compression and which one is the WAV/lossless compression.
http://www.foobar2000.org/
2
But MP3 isn't lossless, and that's a big deal IMO (read my next response for why), and as for which lossless codec, there is no best, there's only "best supported" and the one(s) that work with your player(s).
As far as lossy codecs go, WMA and AAC are more advanced than MP3 and probably better sounding at similar bitrates. I'm sure hydrogenaudio or somebody has listenning tests which compare codecs, eg here:
http://www.rjamorim.com/test/index.html
This right here is necessary and sufficient reason to rip to a lossless codec IMO. Once you rip to a lossless codec you can easily convert to any other codec at any time. You can convert between lossless codecs without loss. Some programs will batch convert your whole library. And for portables, many programs will transcode to a "portable friendly size/format" on the fly. Lossless codecs are simply the most logical choice for a music library period. IMO
WMA Lossless, while it does support DRM, does not require it. It's a perfectly valid format. Like I said above, lossless is definitely the way to go, but which format is best is determined solely by which format your players support.
Unfortunately I've found a pathetic lack of real good audio solutions for the car. What I want is something like a squeezebox, but everything seems to be iPod based.
If I accept that, currently I'm leaning toward a 160GB iPod Classic and highly integrated iPod compatible deck for my car, and just "install" the iPod permanently. I'll just convert my library to Apple Lossless and have my whole library with me in the car.
See less See more
Yes...the OP didn't require lossless however, that was your suggestion..albeit a good one.
WMA lossless is a very good option with MC ripping but @ >5x the storage of 320kbps MP3's, is it really worth it?
I hear what you are saying...
I used to have a McIntosh (MX400 or something like that) head unint in my car and it sounded the best I have ever heard of any car head unit. I just got bored with no features and ebayed it (sad). I not have an Eclipse AVN5510 which sound pretty darned good (though not quite the Mac).
I looked at Denon head units as well but they are similar to the Macintoshes where they have no features.
My amps are Old PPI (before they went to the new crappy design). And my speakers are Diamond Audio Hex comps.
All in all it is a good system, one in which you can hear lots of detail from your source, but not at speed.
See less See more
2
At $100 for 500GB, absolutely.
I was looking at the Eclipse decks, but most recently, the Alpine decks with Imprint are looking very nice. Though the voice-commanded Pioneer decks announced at CES sound interesting as well.
I've got the "old" PPIs as well
Not much you can do about that
See less See more
What about portable storage on your MP3 player?
See less See more
Use J River Media Center or iTunes or something to load your mp3 player by automatically transcoding on the fly to a lossy codec. Why would you limit your archive by the specs of your current portable player?
No thanks to that crap software and always having to transcode, thank you very much.
But really...how much difference between a WMA lossless and 320kbps MP3 anyway?
Is it really as big a limit as you imply? I really haven't checked it out myself.
See less See more
It is a notable difference on a good sound system, but the two can be indistinguishable on crappy a one.
kylebisme, where you live, i'll come over RIGHT NOW and do a blind A-B test with you. I'll bring some snacks too!
Why? And I definitely wouldn't call JRMC "crap software".
If you get a new player that doesn't support mp3, or doesn't support 320kbps mp3? If you ever have to change your codec, yes, it's as big a limit as I imply because if you rip to mp3 you have to rip all over again, else deal with generational losses.
If you keep your library in a lossless format, and get a new portable player, you just have to change the transcode settings. If you get a new player that doesn't support your lossless codec, you can just batch convert the whole library.
1 - 20 of 32 Posts
