Wanted to know the proper and best way for setting up my HTPC audio through my Onkyo receiver with DTS and THX set-up with 5.1. This is my setup. HTPC or XBOX 360 (via HDMI) ----> Onkyo Receiver (via HDMI) -------> Samsung LCD TV
1. Should I use the HDMI or S/PDIF audio connection
2. Should I configure my speakers in Windows 7 as stereo or 5.1? Do I do simply stereo and my receiver then decodes to 5.1?
3. Are there any other settings that I should turn on or off? (note that I use sharky007 codecs and simply checked off sharkys best settings)
One thing I noticed. When I set the speaker configuration to 5.1 in windows, then the receiver simply allows Direct sound or Stereo mode. I cannot use the receivers other audio modes (DTS, Neo, THX, etc). The other audio modes only show on my receiver when the speaker configuration in Windows 7 is set to stereo. My fear is that setting to stereo in wwindows only limits 2 channels to the receiver. Ideally I would like to send the audio in its true nature to the receiver and let the receiver do all the decoding. Any help is appreciated. Thanks.
Windows 7 Ultimate
1 Win-TV HVR-2250 Tuner
1 ATI Radeon HD5770 Graphics Card
2 TB Hard-Drive (RAID 1)
Gigabyte GA-H57M-USB3 MB
Intel i5 Core 650 3.2 Ghz (overclocked to 3.8gHz)
4 GB DDR3 1333Mhz RAM
Silverstone GD05 Case
Logitech DiNovo Mini Keyboard
Windows 7 Ultimate
