1 - 11 of 11 Posts
Bump...
I am also. (For Brother in-Law).
- which paradigms?
- how big of a room?
- listening levels?
- any "must have" options?
Then with that budget and for those speakers you should be looking into either a good pre-pro or AVR with pre-outs and adding an amp. These combinations will give you much better options to be looking into. Don't spend $2K on an AVR alone unless you only have room for this one piece scenario. The amp will be there for a long time, the AVR's change constantly. Next time you upgrade get another lower cost AVR with pre-outs and you'll be good to go. JMHO.
The ones that get a lot of buzz are the onkyo 3/5008 and the Dennon 4311.
The 3008/5008 are 9.2 capable and the 4311 is 11.2 expandable. All three have 9 internal amps.
One feature to shoot for is audyssey x32.
Discussion Starter · #7 ·
paridigms are 2 studio 100's; 2 adp 590's; 2 studio 20's; 1 studio cc-690; and 1 servo 15.
room size is irregular. main part is 23 x 16. rest is 12 x12. all of this area is open.
use is 50 movies and 50 music.
must have hdmi 1.4 with 2 hdmi outs.
If you can demo the Anthem MRX 700.
1 - 11 of 11 Posts
