Hi All,
I am sure this has been beaten to death, but here goes:
What is the "best bang-for-the-buck" sound barrier?
My HT is a typical Plaster/Wood/Fiberglass wall construction.
I have one wall leading to an unfinished part of the basement, which has the fiberglass & studs exposed. I want to add some form of sound barrier to the unfinished side. I want to prevent sound form coming into the HT, as there are several noisy things in the unfinished area (Dehumidifier, Sump-Pump, Sewage Ejector Pump, etc...). I am willing to use whatever works best, and I am not concerned about appearance. But I am also looking for something simple, and relatively economical.
Any advice is greatly appreciated.
TIA
TIA
