1 - 1 of 1 Posts
I have a Samsung HLP5063 that looks o.k. but I know it can look considerably better, so I am motivated to maximize the potential of this set, short of a professional calibration, which I can't afford right now. Anyway, someone suggested I use the THX optimizer to start with, and after that, I'm not sure which would be best......DVE, AVIA, or possibly even Sound & Vision Home Theater Tune-up. Also read that it's almost useless to try and calibrate the input that the satellite box is using because it's always different.......don't know if that is true. Someone said they recorded the HDNET test patterns with their DVR and made their picture a lot better, so I will be trying that also. Also, for whatever it's worth, I use an Oppo DV-980H dvd player.Anyway, and suggestions or advice greatly appreciated.Thanks in advance
1 - 1 of 1 Posts
