Status
Not open for further replies.
1 - 5 of 5 Posts
I would like to connect my Sony dvp-f11 to my monitor. I need some suggestions for a suitable dTV compatible video capture card, compatible with NTSC and PAL signals and preferably more than one s-video input.
Keimar: unfortunately, there is no best card that I would recommend for dScaler. There are hundreds of compatible cards, not all of which are listed in the dScaler cards supported list . Further, the video noise on these cards are governed by any number of factors in your system (power supply, video card interference, etc.). The thing to watch out for is a card with the inputs that you need and with acceptably low noise. I think the Cybertainment has more than one s-video, but no tuner.
Dan
Hi,
I have bought myself a Hauppauge IMPACT. No TV-Tuner, 1 S-Video, 2 Composite. Works great with dScaler (dTV) :))))))
C U, Torsten
C.U. Torsten,
Where can I find info on the Hauppauge Impact?
Mark A. Torre
The Torre Home Theater
1 - 5 of 5 Posts
Status
