And before you ask:
The importance of "timbre matching" is grossly exaggerated. Like most audio folklore, it comes directly from the vested interests of the industry and its advertising-bought, ever-pretentious "golden-eared" audio press. It matters only if you're very nitpicky and MICRO-LISTEN to your movies, as opposed to (gasp!) simply WATCHING them.
(Seldom mentioned is the fact that the ONLY way to get a TRUE "timbre match" is to use a center that is IDENTICAL to your L/R speakers
and is also vertically configured, i.e. having the 3 tweeters horizontally aligned. Any time you combine a HORIZONTAL center with VERTICAL mains, you are
not getting any sort of real "matching"---a horizontal center is just a WAF/convenience-driven compromise.)
To see how multiple people are finding out FOR THEMSELVES just how silly the whole "timbre matching" hoopla is, start with post #19 of this thread:
Do any of you wonderful people have an idea when the C2+ is going to be back in stock by chance? (This csiA6 is super duper meh despite it being traded to me for ceiling fan). Thanks
www.avsforum.com
There are many more threads like that:
Hsu HC-1 with NHT SuperOnes
If an identical bookshelf isn’t performing well as a center (in vertical orientation as designed) then you have some other issue. A matching speaker is 100% the best choice. Sent from my iPhone using Tapatalk
www.avsforum.com
Infinity RC263 used with JBL 590s
The new Infinity Reference lineup is now available and while I do not own anything from this particular lineup yet, I wanted to start an owners thread for us to have some discussion and post our thoughts. So far there has only been one review that I can find and that is from the folks over at...
www.avsforum.com
Infinity RC263 with Emotiva T1, vs C2
Hey all, Hoping to get a little advice on the best options for an upgrade I'm in the middle of. My old LCR Setup: Polk Monitor 50 II - Towers Polk CS10 - Center Just upgraded the towers yesterday to Klipsch R-820F. Went against my (slow, steady, researching) nature and jumped on them as...
www.avsforum.com
Emotiva C2 with Klipsch RP-600M, JBL Studio 530, etc.
I just got the T1+, C1+ and E2’s and the Airmotiv S12 sub, I haven’t been able to hook them up yet as my speaker wire hasn’t showed up yet and the local stores are all closed because of covid.. based on feedback and reviews, it sounds like the Airmotiv speakers are really great for crisp and...
www.avsforum.com
Klipsch RC-62ii with JBL 590:
I'm reasonably certain that the JBL 520 isn't going to be able to keep pace with high volume movies. I have heard some glimmers of shortcomings during my initial test runs of movies that have a lot of action at high volume and the consensus is pretty clear also that the 520 won't ultimately be...
www.avsforum.com
Klipsch RP-450C with JBL 590
www.avsforum.com
Emotiva C2 with Revel F35, and with JBL 530:
www.avsforum.com
Polk 706C with Legacy Signature II:
I have trouble understanding movie dialogues no matter what I do or tweak. Help appriciated. For context my setup : Receiver: Onkyo TX-NR787 Fronts: Jamo S 807 x 2 Center: Jamo S83 x 1 Rear: Jamo S 801 x 2 Height speakers: Polk Audio OWM3 x 4 Subwoofer : SVS SB12-NSD 12" x 1 *Issue *: I...
www.avsforum.com
SVS Ultra center with Polk LSi-9
I added a SVS Ultra center to my system and the sound stage improvement was huge. The sound improvement from my old LSIC was massive.The front height came to life, I did not except this. My whole set-up is more focus, I am listening to my older atmos blu-rays and they sound so much better. I...
www.avsforum.com
Emotiva C2 with Mission 770
Hi all, I have a Mission speakers set up, as I was given a pair of Mission 770 speakers some years ago, which I have built around over the years. I added a 77C center and a pair of 702e's for surround. Both my surround and center are not as good, and I was looking to upgrade. One issue is...
www.avsforum.com
Emotiva C2 with JBL Studio 590
Decided to replace my living room Emotiva set for these bad boys. Wowzers! Ya , that'll work... I absolutely love that entire room ...yo Rocky
www.avsforum.com
KEF Q650 with Polk RTiA3
Sorry to stir up an old thread, can the S30 or S35 be used as side surrounds. Ideally I would like a longish, slim vertical profile side surrounds. Another budget option I am looking at is the Taga Harmony LCR60. Thanks and Stay safe. Might want to look at the HTD on-walls for that...
www.avsforum.com
Emotiva C1+ with Wharfedale Diamond 225
Have some new updates. Emotiva T1+ Front Emotiva C2 Center Emotiva T0+ Surround Monolith 10 sub Dayton 652 Air Front Rear Heights Lovin this stuff :) Thanks Zorba922 for the help I would like to give a huge THANK YOU to Zorba922 for helping me with my choice of speakers. I have used...
www.avsforum.com
Paradigm center with B&W in-wall speakers
Does Timbre matching my speakers mean I need to get from the same line from the same company? I have a Klipsch 250c, so would timbre matching mean I need to get from the same line of reference speakers, or at least Klipsch speakers, or can I mix it up and get KEF or Polk or something? Thanks.
www.avsforum.com
Hecor Aurora with Revel F208
I'm looking for a center channel to match my new Revel Performa3 F208's. However, my amp is 200 watts per channel and max power for most of the Revel centers is less than that. The Revel C208 has a power range of 50 to 350 watts but is $2K, more than I'm willing to spend. So, I'm looking at...
www.avsforum.com
HTD Level 3 with Def Tech BP30
Yes and no. It's not that simple, although it's easy to imagine it is due to the usual compulsive theoretical one-upmanship that often pervades these enthusiast forums. A TWO-way MTM has "lobing effects" which are only relevant if you sit off-center (30 degrees or more) from about 6 feet. If...
www.avsforum.com
