Status
Not open for further replies.
1 - 16 of 16 Posts
What is a good DVD player for a HD plasma? So far Im considering Samsung hd-931, Denon 910, Panasonic xp-30, and Sony dvp-nc 665p for its 5 disc convenience and low price so I can replace easily in the future, btw I dont need any fancy features just decent audio and a good picture.
Any thoughts? TIA
Banned
Forget the Sony it has a poor de-interlacer. The Panasonic XP30 or a Denon DVD-1600 or DVD-910 would be the best choice due it the superior Faroudja de-interlacer. The Samsung has some problems.
Discussion Starter · #3 ·
Thanks Thumperboy, I see in other posts you like the mitsubishi 8040 as well and I also read denon 910 has some issues, so I guess it will be either panasonic xp30 or mitsubishi 8040 which one would you pick, you seem to be an expert in the field and I trust your advice. I guess asking for a multi disc changer leaves me with little or no choices, that being said any decent ones out you recommend with a close picture quality as the one mentioned above? It seems one would be lucky to find a decent single disc for hd. Your insight and information is greatly appreciated.
Regards
Moderator
Nasdbull,
If your plasma has DVI/HDCP or HDMI inputs, you may want to consider
"universal" (DVD, CD, DVD-A, SACD, etc) players with DVI/HDMI outputs.
They are more expensive but offer superb PQ and hi-res audio to boot.
Depends on your budget and setup. Later in the year less expensive
universal players with digital video outputs are coming also.
larry
Banned
The Panasonic XP30 is the best choice I got one a few months ago used on EBAY for $200. The Denon DVD-910 is a little better than the Mitsubishi DD-8040 which I got and tested but took back to the store after I got the XP30 it beat them all! For changers, I've heard Yamaha makes some with the Faroudja de-interlacer, but I have no personal experience with them.
Nasdbull:
I agree with PooperScooper about DVI. I have a DLP and the DVI connection makes a very noticible improvement in PQ. However, I am still waiting for the equipment manufacturers to get their act together because even on the more expensive "universal" players, there are compromises being made in either video and/or hi-res audio that make them unsuitable for me. Not to mention that they are more expensive than they are worth. :D
My current solution is to use a Bravo D1 (the D2 is supposed to be out in Feb) with DVI output for video and a less-expensive universal player that I use for hi-res audio ONLY and, because the bass management seems to be mishandled in current players (especially for SACD), I don't use the DVD player's bass management but use an Outlaw ICBM for those duties.
But for video only (your original question), DVI is the way to go...
If one gets a dvd player with hdcp compliant dvi output and ones display dvi input is non hdcp compliant does that mean that no picture will be displayed ? Or does it depend on the dvd content ?
What would you say to the Denon DVM-1815 or 2815? From what I've read so far, they're supposed to be about like the DVD-910, and both are 5-disc changers. Secrets has positive things to say about it here:
www . hometheaterhifi.com/cgi-bin/shootout.cgi?function=search&articles=112#DenonDVM-2815
Not undercutting your advice Thumper, but looking for confirmation really, as I'm also considering a 5-disc changer and think I have it narrowed down to one of those two, depending on whether I'll end up using the DVD-Audio much or not :)
I've read dozens of threads and hundreds of posts on the 563a and I have never heard anyone say it has the 'chroma bug'. I think this information is dead wrong. Beware what you hear on any forum and make sure you get more than one opinion.
I stand corrected. Pioneer has changed their decoder. It apparently doesn't have the chroma bug but it did fail the Chroma 4:2:0 test, which I assume is not a good thing but perhaps not as much of an issue.
Description of the Chroma bug and 4:2:0 error
It didn't rate all that well in the benchmark tests as compared to the Denon DVD-910 for example, which sports the Faroudja DCDi which is highly regarded. But, it is not a universal player that will do SACD and DVD-A and it costs about $70 or so more than the Pioneer.
Benchmark Results
Regardless, given the price I've been tempted to buy the 563 based on its ability to play the SACD and DVD-A audio formats but my first priority at this point is video quality. I've also read positive reviews for the Mitsubishi 8040. However, I have no personal experience with any of these machines and I'm researching at this point as well.
I second that in the sense that don't just read the posts and make the impression. I bought this player 2 weeks back and absolutely love it. No problems whatsoever at all. Perhaps older players did. New ones dont. In fact I reviwed this player as well sometime back and its in Gearviews. My recommendation is a strong yes for Pioneer 563A.
You should also consider the new Samsung universal/upscaling players available now as pre-orders at incredible prices at Amazon.com, with estimated shipping dates in July).
1 - 16 of 16 Posts
Status
