Status
Not open for further replies.
1 - 1 of 1 Posts
I'm all over the place on which would be the best way to upgrade from my Bravo D1. I can spend up to $1500, but would rather not. The Plv70 is not hdcp compliant so I'm limited if I want to use the DVI input.
I've thought about the Oppo, the Samsung 950 (which I think would work via dvi), and I've also considered more expensive models, using their component out- like the 59avi or the Arcam players. [I also have an arcam 300 on the way]
Does a more expensive player using component outs beat an inexpensive w/ dvi?
Any suggestions?
1 - 1 of 1 Posts
Status
