Originally Posted by zipbags /forum/post/0
And with regards to the HDD. I have a HD dvr. I just assumed it was overkill.
It depends on the model of your HDD DVR.
Is this one you rent from either the cable company or satellite?
If yes, then As Far As I Know(AFAIK), these units have NO type of editing within there systems on the HDD.
Not even some Over The Counter HDD/High Definition recorders(the Sony HDG-250/500 come to mind) have any type of editing features.
Only the HDD's found in DVD Recorders have editing features.
Ones like the Pioneer 640 and the Toshiba XS-35/XS-55(do i have those model #'s right on the Toshiba's?) have editing features galore on those models.
The Pansonic's have them as well, but have that TVGuide system built in. Can be easily avoided on recording, but it is shame it does not work well with alot of people. Not everyone mind you, but alot of people.
You could, I guess, just do the editing on a DVD-R/-RW/+R/+RW on your Panasonic, but you would be doing it in REAL TIME, and be using the PAUSE and/or STOP button to remove commercials/unwanted video.
While playing it back through your HDD DVR, you could be sending it out to your DVD Recorder, and pausing the Panny, then FF the HDD DVR, then picking up the recording again on the Panny.
This would be REALLY TIME CONSUMING, but to each their own.
