First, the bad news: getting reliable UHF DTV reception beyond the curvature of the earth (approximately 60 miles) is difficult. The good news is that terrain has a major impact on reception. Going over water is about the best it gets, since water is generally flat and has positive impacts on temperature for sending the signal along.
Still, at 70 miles, unless you can get direct line-of-sight to the transmitters, the number of things that could impact reception negatively is overwhelming. Know this going in. Accept that what you want may not be possible. Spend your money accordingly.
The RCA-DTC100 is not the best receiver for distant reception. It has trouble locking on to weak signals. Better choices would be boxes from Samsung, Zenith or the new Panasonic. You may have success with the RCA, but if you're borderline having success, a swap of boxes could make the difference.
Good long-distance antennas include the Channel Master 4228 (8 bay bowtie) 4248/3023 (80" yagi/corner-reflector) and the Televes DAT75 (80" yagi/corner-reflector with a unique array of directors.) Invest in a high quality preamp, preferably one of the Channel Master 777x models, depending on your needs. Put the antenna outside, well above the roof line, with a rotor and without any trees in the direction of the transmitter. Use high-quality RG-6 cabling.
If you haven't already, check out http://members.aol.com/_ht_a/kq6qv/A...comparing.html which has a comparative measurement of most common antenna designs.
Good luck!
Originally posted by banshee1 I need a recommendation for a fringe OTA antenna as the only network transmitting HDTV is a CBS station that has two transmitters, one is 70 miles NE of me (1/2 the distance would be over Lake Huron) and the other transmitter is 76 miles SW. |
Good luck!
