Status
Not open for further replies.
1 - 2 of 2 Posts
I have a good center and sub but I need to upgrade the fronts and surrounds. I was looking at the Paradigm Atoms and Paradigm surrounds but is there anything better?
Best results will be obtained if the left/right/center channel speakers are from the same manufacturer. Timber matching will eliminate tonal discontinuities as the action on the screen moves from left to right and vice versa. So the direct answer is, if you like your center channel, buy left and right speakers from the same company.
1 - 2 of 2 Posts
Status
