I'm new to the Audio world, and was wondering how I should get sound from my Auzentech Prelude to my Speaker System.
AV123 ELT525M (I hear these need lots of power to sound their best)
Gateway KAS 303 Center (similar to HSU ventriloquist, may be replaced at a moment's notice) and Subwoofer (similar to HSU STF-2 /w 150watt amp)
(surrounds are undecided at the moment)
30" Dell 3007 WFP 2560x1600 or 32" 1080p HDTV (no wider than 31.5")
HTPC:
Phenom 9600 BE or Core2Quad E9550
4850 crossfire or GTX 280
Auzentech Prelude 7.1
LG GGC-H20L BD/HDDVD Rom
Artec USB HDTV QAM Tuner
50/30/20 Gaming/Movies/Music
I've got a Yamaha RX-V363 and a Harman Kardon 146 at the moment, and am considering buying a Yamaha HTR-6890. I'm wondering if my current receivers are enough to power my system (I hear the ELT525M's sound better with more power).
Is analogue multi input the best way to get HD Audio to my receiver?
Do I need the HDMI support as no true HD Audio can come through there at the moment right (except the PS3)?
Is a multi channel amp an option? Are there any within the $200 range that I can afford?
HTPC:
