I'm curiious which HD camcorder gets the best indoor low light footage...
Originally I was considering either the Sony HDR-SR1 (HD) or the Sony HDR-HC3...
I'm open to other options as well.. I've looked through this forum as well as camcorderinfo.com etc...
It would appear the HC3 gets better PQ than the SR1 based on camcorderinfo...
Are there newer models, now out, that are even better than either of these two?
My old camcorder is a DV Sony TRV-310, which did very well, 1 LUX (according to sony).. I've seen these units are at about 4 LUX.
I also am still waivering on the Hard Disk vs MiniDV idea.. I like the idea of a solid tape backup and being able to simply stick in a new tape when the other runs out, whereas with a HDD unit, when your out (on the road), your out.
I'm not really convinced HDD will be the future, perhaps faster/better solid state cards like SD/XD, etc?
Price range isnt a problem though I'm assuming for a good HD camcorder it will be b/w $1000 and $2000.
Also.. isnt it as simple as throwing on a hotshoe Light on say the Sr1 or the HC3 if recording indoors (that will feed off the battery and not need a/c power?).. If so then low light issues become almost moot?
Thanks for any thoughts/new model ideas.
