I have a Sharp 9000 with the firmware update. I am wondering if it is worth getting a Panny HD receiver. Since it allows one to output 720p, if I put this into Input 5, I assume it will avoid the internal scaler.
On the other hand, if I get a DTC-100, it only puts out 1080i. It seems this will trigger the internal scaler.
Is this thinking correct, or more importantly, relevant?
Someone said that it doesn't matter. Either the receiver must do the scaling or the Sharp. They said it was the same difference. Is that true?
Thanks in advance.
John
Thanks in advance.
John
