So I've set up with Active (powered) monitors and I want to be able to adjust the volume with a remote control (which my monitors don't have). Here's the gear list:
Mackie HR824 (2, L/R)
Mackie HR626 (1, Center)
Either Genelec 1029A (2) or Paradigm Mini Monitors (which are passive) (2) or both (satellites)
Krok Rokit 10 (1, Sub)
Samsung LN-S4095D (1080p HDMI LCD)
Samsung BD-P1000 (Blu-Ray)
Motorola (Comcast) DCT 3412 I HD DVR (HDMI Cable box)
Original Xbox
CD Jukebox
Right now what I'm doing is just using the surround outputs on the Blu-Ray player direct to their speakers and using a simple switcher to listen to 2-channel HDTV and CDs. This sucks not only because of the lack of volume control and mute, but because I can only get HDTV in 2 channels...no 5.1 decoding. Worse, the BD-P1000 only does 5.1 output on Blu-Ray discs (yes I updated firmware to 1.0), not on DVDs! I hope that it will pass 5.1 audio via HDMI from DVDs (does it?).
So I'm looking at receivers like Denon's AVR987 (aka 2807) which have preamp outputs that I could hook up my active monitors on. However, I can't determine anywhere if those preamp outputs are post-fader wrt volume control and muting (manufacturers of consumer gear often make them pre-fader so users won't need to learn proper gain staging). The LN-S4095D TV has its audio outputs pre-fader, so I can't even use the volume/mute control on the TV outputs! Nor does the TV allow any DSP to be applied to its audio outs! Ripoff, but again, the consumers (even the reviewers) would just get lost if they provided proper control and the equipment would get wrong-headed complaints on forums like this.
I don't need an amplifier of any distinction (if at all) of course, just HDMI switching passing 1080p, surround sound decoding and direct outputs, remote volume control and muting for those direct outs, high-quality converters (at least 2496), perhaps some DSP like volume leveling if it's done really well (that's hard btw). I would prefer balanced outputs (1/4" TRS or XLR) but those aren't totally necessary. Ideally, I spend less than $1000 on a box that does all of this too!
(Note also that I would like HDMI support for the Cable box...I heard some of the receivers were having trouble with HDCP or something from the Comcast cable boxes...is that problem solved yet?)
If the Denon works then I'm all set with that (unless you have another option). If they purposefully prevented the preamp outs from being post-fader/post DSP, then I'm hosed with that option and need something else. Does anyone know what the Denon does, what other consumer-level AVRs do, and whether there's something that's an ideal fit for this setup?
Original Xbox
CD Jukebox
