Wondering if solid silver would be the best internal wire for subwoofers and how it might change the sound for better or worse compared to solid copper (building a sealed 6.5 cu/ft with a CSS SDX15). Would it improve in say definition and speed but sacrificing the lowest frequencies.
The plan would be to either buy OCC bare 24 gauge for just over $2 or teflon coated for just under $5. Then I would twist enough runs together to make it 12 gauge equivalent. Otherwise if silver is a bad idea I would just go with one solid OCC 12 gauge copper run unless there are better ideas.
