best multi region dvd player 100.00 or less
491 Views 5 Replies 3 Participants Last post by  js1
any ideas?..
Status
Not open for further replies.
1 - 6 of 6 Posts
The Philips DVP642 is popular - 62.94 at Amazon. I have a Toshiba SD-4900 which has worked very well - Discontinued, but readily available on ebay for under $100.
thank you, are these RF out of the box?
uummm dumb question here...but the spec on amazon says this player can play region 1 or all region. Does this mean it can also handle region 3?
Does "all region" mean it any region?
This should help:
http://www.videohelp.com/dvdhacks.ph...hilips+DVP+642
does anyone know how it handles pal/ntsc conversion?
1 - 6 of 6 Posts
Status
