Hi!
I'm building a new house and am having them pre-wire the surround sound in the basement for my future home theatre.
With that, I need to tell them where to put each speaker ahead of time. The part I'm having trouble deciding on is where to put the subwoofer. I realize that the best method is to move it around to see where it sounds best, but since I have to tell them where to have the RCA come out at, I figured I'd ask you guys!
I've included a layout of the room. All the wires will come out in the closet in the top right corner. I'm still deciding between a 110 and 120" projector screen, but it looks like I can fit the sub under the screen, next to the center channel if needed. I have 8' ceilings. The yellow circles are can lights, each set controlled by a different light switch.
Where do you think I should tell the builder's electrician to run the sub's cable to?
