Status
Not open for further replies.
1 - 4 of 4 Posts
hello
i just set up a htpc, i got a mitsubish WS-65819 rear project connected to the pc via a RGBHV cable, please post your powerstrip settings for desktop, divx movies, and dvd. I have the original radeon 64 vivo. I use the default 720x480p setting it's ok, i was wondering if i can get better or higher resolutions.
thanks
Desktop rez (Mits HDTV):
PowerStrip timing parameters:
848x480p @540p timings=848,90,88,62,480,28,5,50,36500,336
Generic timing details for 848x480:
HFP=90 HSW=88 HBP=62 kHz=34 VFP=28 VSW=5 VBP=50 Hz=60
+hsync +vsync
DVD playback rez (Mits HDTV)
1440x480p @ 540p timings=1440,123,136,93,480,28,1,54,60117,336
Generic timing details for 1440x480:
HFP=123 HSW=136 HBP=93 kHz=34 VFP=28 VSW=1 VBP=54 Hz=60
+hsync +vsync
Discussion Starter · #3 ·
Thanks Karnis
which version of ati driver do you use? i'm using 6.13.10.6071, i don't think it supports custom resolution.
I'm a Win98se user, running the 9009s.
You might want to try the 6025s for HTPC stability/ custom rez...this is what I've read but again, I'm a 98 kinda guy. You want to be very wary of leaked ATi drivers, it's a whole different world that leaked nVidia drivers....stick with ones proven to work, IMHO.
1 - 4 of 4 Posts
Status
