Status
Not open for further replies.
1 - 4 of 4 Posts
I am getting a new HTPC with the following components --
Pentium4 2.8c @ >3gig (edit: hyper threading will be disabled.)
Abit IC7-Max3
OCZ 256x2 (512meg total) PC4000 gold
Sapphire 9800 pro
My display will accept 1280x720 at 60 as its highest native resolution and that is what I'd like my desktop to be. This machine will be used for TT and ffdshow.
What is the best driver for this? rage3d or omega or other?
Thank you for any comment
videolover
Got a 9700Pro => DVI => Marantz-S2 at 720p.
I have been using "standard" CAT3.7, since they were released a few weeks back - no problems during "normal operation". However, I had some problems getting the 720p resolution in the first place. (I resolved it by installing PS, selecting 720p through PS, then de-installing PS, 720p remains "registered") I am not sure if with other drivers I had not gotten this issue.
____
Axel
Originally posted by videolover
Has anyone tried the omega drivers?
Yep, about 3 weeks ago. It screwed up my system so badly that I had to do an emergency re-install of an earlier image (thanks to DriveImage). I actually tried it twice... However, I am sure that others had more success and can chime in.
_____
Axel
1 - 4 of 4 Posts
Status
