1 - 6 of 6 Posts
· Registered
Looking for receiver to drive speakers listed below. I will be listening to mostly (in order of importance) sports, Jazz, and movies. I have looked at a few receivers and the Denon AVR 4810CI and 3310CI are on the top of my list, but I am open to suggestions. Price range for receiver is $2500.00
1. Focal Chorus 826v (front speakers)
2. Martin Logan Grotto i (Sub)
3. Focal Chorus SR 800v (Rear Channel)
4. Focal CC 800v (Center channel, BUT considering replacing w/an in-wall Paradigm or something similar)
Michael
· Registered
you might check in the focal thread--many have opinions on this very subject. People seem to like arcam and nad. opinions vary on denon/pioneer. you might also consider an integra 40.1 prepro and an emotiva amp in that price range.
· Registered
I'm in the same boat you are. Finally have my 816v's broke in and my Pioneer is definitely not cutting it. I have the Denon's hooked up to 836's at work and they're a good match. If I were you, I would do the 3310ci and use the remainder of your budget and save up a little more for a separate. Maybe a Parasound 5125 or something similar. That's the path I plan on taking. Good luck!
· Registered
I own 836's and I would have to say Arcam and if you can swing it the 500 or 600. They really make the 800 series sing. I own a Denon 3805 and it makes then sing not so much. This is not even close. The 350 is clearly better on them than a Denon or a 280 if you pocket book is more limited.
1 - 6 of 6 Posts
