There are a lot of Klipsch Reference owners out there so I'm looking for some direction on an A/V Receiver. Before I begin, here's my current setup:
Fronts: RF-52 II (100W RMS / 400W Peak . 36Hz-24KHz ± 3dB )
http://www.klipsch.com/rf-52-ii-floorstanding-speaker
Center: RC-52 II (125W RMS / 500W Peak . 67Hz-24KHz ± 3dB )
http://www.klipsch.com/rc-52-ii-center-speaker
Surrounds: RS-42 II (75W RMS / 300W Peak . 62Hz-24KHz ± 3dB )
http://www.klipsch.com/rs-42-ii-surround-speaker
Sub: Sub-12 (24-120Hz +/-3dB)
Receiver: Yamaha HTR-5960
http://usa.yamaha.com/products/audio..._u/?mode=model
My receiver doesn't have HDMI input, hence no HD audio support. So it's time for an upgrade. Now of course the drive behind this upgrade is to obtain higher quality sound with the new Blu-Ray HD formats, but if I'm going to upgrade I want more than just support for the codec. I want great sound. I want something that pairs well with my Reference speakers, but I don't want to pay a bunch of money for power or features I don't need. I've been known to crank it up, but I don't listen to these things at ear bleeding levels. I also don't think I need network support on my receiver, since most blu-ray players offer the same sorts of services with their network support. I don't THINK I would ever expect to spend over $1000 on a receiver, and I'm used to waiting around and getting things for 50% off... for instance there are some $1000+ receivers that are around $500 right now. But hey, I'm willing to spend a couple hundred more if it means getting something that's great.
SO TO MY QUESTION... what the heck should I get?
I've been leaning towards Yamaha but that's really only because I'm familiar with them and so many people speak highly of their quality. I've been eyeing the AVENTAGE line, but I'm not sure if I should go with the RX-A1000, or if the RX-A800 or even RX-A700 would really give me the same result with my set of speakers. I mean are we just talking about unutilized power, feature differences, or honest to goodness sound quality difference. Then I guess I'm really not sure what the difference is between the AVENTAGE line and the normal RX line.
And of course other people say Onkyo (though I've heard about build quality issues?), and others Marantz (though they seem expensive), and more recently I've seen those that shout Pioneer Elite (which I know nothing about). More recently I've been eying Emotiva and a combination of a UMC-1 processor with an XPA-5 five channel amp.... but that starts to get a lot more expensive and I have no idea if my particular class of speakers would even take advantage of such luxuries, or if I would notice.
I think the most prevalent thing here is that certain brands have different sound, and I'm just curious which would go best with some mid-road Klipsch Reference speakers like I have. Some people say Klipsch is bright, and Yamaha receivers are bright, so it's a bad combination... but others swear differently. And then I'm not sure if newer or higher end Yamahas, like the AVENTAGE, don't have that same brightness that some people refer to.
Most of the other help I've sought is random opinion with very little experience... unfortunately even on the Klipsch forums. There seems to be more experts here. I anxiously await to hear what avsforums has to offer!
