Status
Not open for further replies.
1 - 4 of 4 Posts
I'm trying to set up a friend's Sony XBR (don't know the model number, but it is from 2002) with his pc, and I can't find the best resolution and refresh rate. Does anyone have any recommended settings for this CRT and a HTPC? Thanks for the help.
Wright
Banned
1920x1080 at 29.970 Hz interlaced
you will need to use component or DVI output
svideo is by nature limited to 720x480i
anything else you set your video card to when using svideo gets scaled to 720x480i for output
1 - 4 of 4 Posts
Status
