Hi folks,
I'm in the middle of planning my new house and have to make some decissions for choosing screens. Unfortunately I have no dealer at hand which has a wide selection of brands. As I am located in Germany the most offered manufacturers are DAVISION and IMAGE.
Short explanaition what I'm looking for. I will have a dedicated home theatre in the basement which is going to be a bat cave. But this project has to stand behind building the house and is going to be finished later (building houses is quite expansive here).
I'm planning a second set up in my leisure room. And this is the project I'm needing your help now. The leisure room has quite a lot of ambient light which is dimmable but I strongly prefer not to use this option extensively. I know, there goes the black level, but this is not my main focus because for cinema there is going to be the dedicated cinema room in the basement. The main focus is to watch TV (news, dokus and a lot of sports, soccer mainly) which is material black level is not the most important thing. Of course I dont want to exclude the possibility that the setup wont be used for a few films (especially when the main theatre is occupied) but it is not the common every day usage.
Because of the combination usage the only option for the leisure room is a In-cieling screen. A big flat screen is not an option because on the one hand it cannot dissapeare like a cieling-sreen and on the other hand even a 65'' solution would be simply too small for my taste
... yes, I think size matters a lot and the flat screens are cute but nothing for grown-ups
The next point is, that I dont want a light cannon. Not for now but in the near future I am strongly looking for LED-based projectors because of the big advantages for every day usage (switch the projector on for watching the news or a TV show without worrying about lamps etc.). Of course I'm not going to buy the very first LED machines and I'm going to wait for brighter ones but I think 1000lumens is the magic number to wait for (to get the new projector within my lifetime is an important thing too).
The screen size should be something about 220cm to 240cm (width) but I'm willing to compromise the screen size if I have to. I'm also willing to black out direct sunlight on the screen. I also have high flexibility for mounting the projector.
I have not much expirience with screens, I have used a simply white one for a similar setup (175cm on a SIM2 HT380) which I have exchanged for a 0.8 gray one for better black level, as I am using the current setup for everything. I'm strongly playing with the thought to use a high gain solution the next time but all my local dealers are trying to talk me that out. They argue with the degree-dependence (this setup is only used for one or two viewers at the same time) and mention some kind of pearlescent colour in white areas of the picture and so on.
I know many people are very happy with their high-gain setup here in this forum. What do you think is the best solution for my problem? If you think high-gain setup is a good choice for me it would be great if you can write me some recommondation because I have to ask my dealers for these ones as they have no high-gain solution in their protfolio.
