Status
Not open for further replies.
1 - 9 of 9 Posts
I just got a Barco 1208/2. I am running it at 1024X768 @ 75hz and it is unreal!
Does anyone know what the best resolution would be for DVD playback, 4:3 format?
Gerald
I run mine at 1280 x 720 @ 72Hz. I've tried 1440 x 960 and the 720p setting seems sharper for DVD material.
Originally posted by GeraldK
The max Horizontal freq is 135. I can see scan lines from 6' away. Viewing distance is 17' . It's a very sharp and crisp image.
Gerald
How big is your screen? 17' seems like a long way away. This projector produces an image that is good enough to sit closer to.
I sit 11' from a 87" wide and everything is smooth.
Discussion Starter · #7 ·
Chris,
I have a 8' screen, 96" wide. I can move closer, it just leaves alot of empty space behind us. At 11' I would have 14' of empty space behind me, perfect if we added a extra row of seating, but we would never use them.
I was looking at your unistrut mount. Did you have any problems with magnetic interference using the Unistrut with the Barco? I tried using unistrut with my Sony and I could not be within 18" of the tubes with out magnetic interference. Or should I even be concerned about it?
Gerald
Gerald, if you have as much space as you do, its worth moving seating closer, for a better image.
Yes, the unistrut would cause a magnetic field difference than if it was not present, but if you do convergence with the unistrut in place, you can easily compensate for it.
I have not had any problems with magnetic interfernece from the strut. My set up did not change much between on the floor and after I mounted it with the strut.
1 - 9 of 9 Posts
Status
