It depends on your sources, your screen gain and size, your projector G2, your scaler, your cables, etc!
As indicated, use Avia to set the settings correctly for YOUR setup. Everyone else's settings are meaningless.
If there was only ONE right setting, it wouldn't be adjustable. The manufacturer would simply set it and leave it.
Kal
