I'm ready to add a shaker to my home theatre, and have done a fair amount of research, but am having trouble concluding much.
My capabilities and limitations are:
The Buttkicker seems best thought-of, but the cost gets rather high and the power requirements are right out of the park; their amp is a power fiend.
Other units might work well with the subwoofer amp at Parts Express . For example, the Crowson TES 100 uses 50-500 watts. But this is an under-chair mount; does it shake the floor at all for people not on the couch? The Aura Bass Shakers are well-known but regularly accused of being ineffective, unresponsive and indelicate. Certainly they're cheap. Do they do the job? And aesthetically I prefer the Clark Synthesis models but they don't seem widely known here. Would they work well for my application? And which one? I note that the price seems to linearly increase the force-per-watt .
So my question is, given those priorities (not too much power, price is a factor but could go to $800 if pushed, prefer under-floor mount and need sufficient shaking for that application), which would you do? Several Auras? One of the Clarks? Or can the Buttkicker fit into the power profile?
- Prefer to mount under-floor so everyone can feel it, not just those on the couch
- For aesthetic reasons, if it's not under-floor, the Crowson would be best, but again I prefer under-floor.
- Willing to spend about $800 total, though less is good
- Plan to use just for LFE off the subwoofer channel
- The power circuit already has a powered sub, Denon receiver, Plasma TV, panamax, dish and DVD on it, so 250 Watts would be okay but 400 Watts may be over my limit
- For same reason, efficiency is highly prized.
