Can you be more specific on the size? What's your budget as well?Any recommendation for rear speaker for use in 7.2 setup? I can do wall mount or ceiling mount but need small size.
Thank you in advance.
What about a second pair of A130s?I have JBL stage A180 as LR, A130 side surrounds with infinity center. I am trying to find in less than $300 for pair. In terms of size, don't prefer to look too big since this is not a dedicated HT, so may be something like Polk S15 would work? Are there better options?
Thanks for the input.
The ports only factor into the equation at around the 60Hz point. If you're crossing your surrounds in the 80-120Hz, the ports won't be a problem. You could also plug the port, too.Hi Ryan - I was thinking the same but they recommend not to rear wall mount since they are rear ported?
They're surrounds, so they will not be doing hardly anything in the low frequency range, where that port comes into play. I'd would say get the A130's too, since they match your setup and are inexpensive (if on sale) and will do the job. I wouldn't mix some signature Polks into this at this point.Hi Ryan - I was thinking the same but they recommend not to rear wall mount since they are rear ported?
Those OWM3s start at 100Hz, so you really should be crossing them over at 120Hz.I'm using Polk OWM3's for side and rear. Audyssey crosses them over at 100hz on the sides and 80hz on the rears, which are corner mounted, so seems about right. They do okay in a small room (11' x 18') with JBL 580s and an Infiniti RC263 up front and a dedicated sub. They are fine for surround duties, but nothing special. At $150/pr they are cheap enough to try out. I chose them mostly because I needed something shallow in depth and they are only about 4" deep.
I agree you should try another pair of A130s though.
JBL Stage A120 is a little smaller than the Stage 130I have JBL stage A180 as LR, A130 side surrounds with infinity center. I am trying to find in less than $300 for pair. In terms of size, don't prefer to look too big since this is not a dedicated HT, so may be something like Polk S15 would work? Are there better options?
No, they are rated down to 80hz. It's +/-3db that starts at 100hz. But in any case, I measured them with Audyssey and used REW to confirm and they are fine at 100 hz in my room.Those OWM3s start at 100Hz, so you really should be crossing them over at 120Hz.
You go by the -/+3dB spec. But anywayNo, they are rated down to 80hz. It's +/-3db that starts at 100hz.
So getting some JBL to match as close as possible to your existing JBL is going to be your best bet.
Nice thing about the JBL A-120: they come with wall-mounting brackets.Thank you for all the info and recommendations. Going with JBL make sense and good to know other options as well.
