Hi all,
I posted a thread a bit back about subwoofer selection, and need another round of input as the situation has changed a bit as to the size that I can fit into my spot.
Basically, I want some ideas as to the "biggest bang" in the smallest package... I had originally thought I would be able to fit upwards of 24" cubed, but now I would be pretty lucky to fit about 14" cubed...
I know that it will entail a sacrifice on output, etc on my part, but it is what it is... at least I can maybe get a better quality sub for a $600 budget because it will be smaller?
Thanks for any and all advice/input... it is kind of frustrating for me, but I want to be able to do the best that I can with my new restrictions...
