1 - 20 of 41 Posts
I've finally made some decisions on a new receiver and front 3 speakers, and would appreciate some advice on the subwoofer that might complement my system.
Receiver: Pioneer SC-1222-K (7.2 - 600W)
Front L/R: JBL ES80
Center: JBL Studio 120C
Mid/Rear: Onkyo SKS-HT540 speakers
Subwoofer...?
My room is quite large at 15'x20' (15' vaulted ceiling) and open to kitchen and a few small front rooms. Subwoofer options that I am looking at include:
1 - JBL Studio 1 Series SUB150P (300W/500W) - $180
2 - JBL ES250PBK (400W/700W) - $200
3 - Energy Power 12 - $235
4 - MartinLogan Dynamo 300 - $300
5 - Klipsh RW-12d - $350
While these are the subs I have taken a liking to given their balance with price/performance...if you know of any killer deals out there just let me know! I would appreciate some comments...
Banned
The Klipsch RW12d is probably the best performer especially for extension/depth.
The Jbl ES250PBK looks to be very good for the price, but Jbl has a reputation for subwoofer plate amp failure so do some research on the failure rate of that model.
The other Jbl has a slightly weaker amp and a smaller 10" driver which would negatively impact frequency response compared to the Klipsch RW12d and Jbl ES250PBK.
The Energy is a little under powered and has weak frequency response/extension.
The Martin Logan is on sale for 130$ on amazon, but even if you bought 2 it wouldn't be enough for a large room with it's 8" driver and 75 watt amp.
Another option would be to buy 2 cheaper subs like Bic F12's, Bic V-1020's, Bic V-1220's, Dayton Sub 1200's, etc.
However if the Jbl ES250PBK doesn't have a high failure rate and performs close to it's spec there are very few dual sub purchases that would be more cost effective.
word on the net is the jbl has amp problems...how about looking at the PA-150. Does not extend the deepest but will have twice the output of anything mentioned above from 40hz on up.
While the Pa-150 certianly isn't flat to 25hz, it's not a 40hz mid-bass module either:
http://www.data-bass.com/data?page=systems&col=name&type=0&sort=asc&mfr=-1
The Pa-150 is down 4 db from 40hz to 31.5 hz easily making it a decent 30hz-40hz performer. The port tune is 25hz but it's down 10db by that point which would be a noticeable drop even after room gain.
For comparison the Outlaw Audio LFM-1 Ex is 10db down from 31.5-16hz at it's lowest tuning (one port plugged) and 9db down from 31.5-20hz at it's highest tuning.
It's specs are +-2db at 16hz (one port plugged) and +-2db at 22hz (no ports plugged).
The Pa-150 does perform very well up high but it is also a fair bit better (9db better at 20hz) than another popular budget sub, the 22hz rated Bic pl-200 down low as well.
Many Jbl's have had amp issues which is why it's good to proceed with caution but that's not to say they haven't strived to improve that.
Originally Posted by Mik James  /t/1475250/best-subwoofer-for-350-or-less-large-room#post_23379871
yes its great subwoofer for the money...not sure why you quoted my post as I am familiar with everything you posted.
No matter what, take that Energy sub off that list. Energy used to make very high quality subs for the money, but that sub is just WEAK plus gets down to only 35hZ...for a 12 inch sub? My Energy s10.2 subs that are 10 inch subs get down to about 24hZ easy.
So I wonder why the PA-150 doesn't handle anything down below 35hz-ish well? I'm sure more power would help, but I thought I remember reading that someone ran the numbers in WINisd and they said if you raised the tune to something like 30hz or 32hz it would really bring up the SPL numbers around 30hz and make it more in line with it's 40hz+ numbers.
It does look like it has a ton at 40+, but if the Klipsch goes quite a bit deeper then it might not be worth the extra $50 or so (if the Klipsch is back at $300 soon).
Banned
Originally Posted by ousooner2  /t/1475250/best-subwoofer-for-350-or-less-large-room#post_23381995
Rule #1 of loudspeaker design: There's no such thing as a free lunch. You may design a driver/speaker to go lower, you may design a driver/speaker to go louder, but you can't design a driver/speaker to go both lower and louder without making it larger and/or more expensive. This is a codicil to Hoffman's Iron Law, which not even Chuck Norris can break.
Originally Posted by basshead81  /t/1475250/best-subwoofer-for-350-or-less-large-room#post_23379564
Agreed. Should have enough output down into the low 30hz range. Other subs may have better 20hz extension, but if they don't have enough SPL, what's the point of having the extra extension and not having enough above 30hz output?
I may have been nit picking a bit, but the way you worded it made it sound as though the Pa-150 suddenly dropped after 40hz when in room it should be easily good to 30hz.
It doesn't look like a great deal either way for around 370$ on amazon though when the Klipsch regularly goes on sale for around 300$ and the Jbl is 200$.
Unless the pa-150 can be had for less elsewhere?
Originally Posted by Mik James  /t/1475250/best-subwoofer-for-350-or-less-large-room#post_23383674
It doesn't like a great deal either way for around 370$ on amazon though when the Klipsch regularly goes on sale for around 300$ and the Jbl is 200$.
no i was just pointing out where it shines compared to other subs in the same price category...either way no biggie.
l
the pa150 has more lowend output than the klipsch or any sub in its price class... 93db @ 20hz 2m. It just looks like it does not because of the plethora of midbass output it has. you would need 4 rw12's stacked to equal the midbass of the pa150.
Banned
Originally Posted by basshead81  /t/1475250/best-subwoofer-for-350-or-less-large-room#post_23383869
As an owner of three Klipsch subwoofers, I can safely say the above qualifies as a gross exaggeration. This is based on room measurements and not conjecture.
In the next few days when I set up to do sweeps, I'll see what I come up with using four and one meter (at the wife's listening position) measurements as currently, at the main listening position, we're easily able to reach a measured 108dB and at the wife's listening position we're easily able to reach 114dB which are 4m measurements.
Of course, the wife is out on the front porch when I'm doing this.
Originally Posted by BeeMan458  /t/1475250/best-subwoofer-for-350-or-less-large-room#post_23383918
the pa150 hits 118db peak 2m ground plane...the rw12 measures roughly 105-107db 2m or 116db 1m. 3 more rw12's colocated would add another 10-12db. whats a gross exaggeration?
in the lower bass they are probably similar 1 for 1...i am just pointing out how much midbass a pa150 has. Its up there with a rythmik FV15HP and more than a PB13U.
Banned
Originally Posted by basshead81  /t/1475250/best-subwoofer-for-350-or-less-large-room#post_23383989
the pa150 hits 118db @ 63hz 2m ground plane...the rw12 measures roughly 105-107db @ 30hz. 3 more rw12's colocated would add another 10-12db. whats a gross exaggeration?
What does the PA-150 measure at 30Hz which is the figure your using for the Klipsch?
At two meters, with three subs, we're easily able to reach 117dB and this is 22Hz to 150Hz at +/-3dB with the exception of a small -4dB room induced null at ~80Hz. The comments are based on real world, in room measurements, not manufacture's specs.
As I posted, when doing some room measurements, if I can, I'll do some measurements and see what I can find. In my opinion, based on in room personal measurements, it's a gross exaggeration. I see that Data-Bass has one measured and we all know that we're worried about output in the
Originally Posted by BeeMan458  /t/1475250/best-subwoofer-for-350-or-less-large-room#post_23384013
Have you measured the output of a PA-150 or are you going off manufacture specs?
Supposed to memorize which subs are on here, like the rest of us
http://www.data-bass.com/systems
Banned
Originally Posted by cel4145  /t/1475250/best-subwoofer-for-350-or-less-large-room#post_23384019
Ya got me. I was slow on the uptake but ended up there and amended my comments accordingly.
(and please, none of my comments are intended as a knock on the PA-150 as I'm just keeping it real)
1 - 20 of 41 Posts
