What are you using for a sub crossover freq? Either of those subs would be great - I assume you have room for either behind your couch?
Originally Posted by billybob_jcv What are you using for a sub crossover freq? Either of those subs would be great - I assume you have room for either behind your couch? |
Originally Posted by ggunnell An SVS cylinder on it's side is the classic 'behind the couch' sub... You should be able to get a 20-39PCi delivered within your budget |
Originally Posted by PFury67 Hmmm, what do you mean by on its side? |
Originally Posted by ggunnell If you have 5' of space to work with I'd get the new PB12NSD instead of the 20-39 cylinder. I'ts tuned a little lower than the cylinder, and it won't stick up behind the couch |
