Trying to watch a movie or TV program in a bright room is downright frustrating. As you strain your eyes to follow the scenes, you might find that no matter what you do, you can’t get a good picture without a reflection. You may find yourself always having to reposition the TV and your furniture in vain to avoid the reflections and washouts caused by bright rooms. If this is the case, you could benefit from a new TV.
The average display quality in most TVs is pretty good in most rooms. It’s normal for most TVs to have some reflection during certain times of the day. However, if you have a room that has a lot of windows or high ambient lighting, the glare caused by these lights can significantly affect the overall display.
Programs with darkly lit scenes are mostly affected by too much light in a room. You can often adjust light settings in the room or close curtains or blinds to counteract the bright lights, but if that doesn’t work, consider investing in one of the following TVs.
LED TVs are good options if you need a brighter TV to counteract the light in a room, whether natural or artificial. Here are some of the best-LED TVs on the market that will improve your TV watching experience.
We earn commissions from purchases you make using the retail links in this article. Learn more about how this works here.
1. Best TV For HDR Content: Vizio P Series Quantum X 2020
The Vizio P Series Quantum X 2020 has a 4k resolution and is one of the best-LED TVs on the market for watching 4k HDR content.
The Vizio P Series Quantum X 2020 is one of the brightest TVs on the market. It has a wide color gamut display covering the DCI Pe color space found in most HDR content. The local dimming feature and the VA panel has an impressive contrast ratio.
3093409
One downside to this TV is that you might see occasional image duplication caused by the blacklight’s flicker.
Another thing to keep in mind is that if you are still using DVD players or cable boxes, the Vizio P Series Quantum X 2020 might have trouble upscaling that lower-resolution content.
CHECK PRICE
Pros:
  • Best TV for HDR content
  • Displays bright colors and deep blacks
  • One of the brightest TVs on the market
Cons:
  • Color accuracy needs improvement.
  • Occasional image duplication
  • Not ideal for DVD players or cable boxes
2. Best LED TV For the Price: Hisense H8G
Considering its low price, the Hisense H8G performs very well and stands up against higher-end models just fine.
The Hisense H8G LED TV is also a 4k TV, but it tends to cost less than other LED TVs. It comes with a built-in, easy-to-use Android TV that includes plenty of apps ready for download, so you don’t need to pay for a second device.
3093410
It handles reflection in bright rooms well and has a brilliant enough display to combat glare from windows or overhead lights. HDR content is also well displayed by a wide color gamut, although overall brightening in this mode is less than other models.
If you’re looking for a TV that upscales lower-resolution content from DVD players and cable boxes, the Hisense H8G will do it.
CHECK PRICE
Pros:
  • High-end quality for a low price
  • Built-in Android TV
  • Bright display
  • Improves low-resolution content
Cons:
  • Narrow viewing angles
  • Uniformity issues
3. Best With Color Accuracy: Sony X950H
If you’re looking for a TV with automatic color accuracy and no need for color calibration, the Sony X950H is an excellent place to start.
The color accuracy of the Sony X950H is excellent straight out of the box. HDR content looks great thanks to the wide color gamut and ideal peak brightness. The “X-Wide Angle” technology for Sony gives you a pretty good viewing angle, although it’s not suitable for a room with a wide seating arrangement. It also has a good local dimming feature that improves contrast.
3093411
Unfortunately, if you need a good gaming TV for a bright room, the Sony X950H doesn’t come with any gaming features, and the HDR input lag is high for most gaming experiences.
CHECK PRICE
Pros:
  • Best color accuracy
  • Good for HDR content
Cons:
  • Wide-angle could be better
  • Not good for gaming
4. Best TV At Handling Reflections: Hisense H9G
The Hisense H9G is a low-cost option that handles bright environments and reflections incredibly well.
Hisense H9G is a great 4k LED TV that gives you a gratifying HDR experience for the price. The wide color gamut and its ability to make highlights pop make viewing movies a pleasure in bright rooms. Its bright screen efficiently combats glares and makes reflections a problem of the past. On the other hand, its contrast ratio and black uniformity perform well in dark rooms.
3093412
The only downsides to this TV are the narrow viewing angles and lack of gaming features. However, it does have a quick response time and a low lag input if you’re a casual gamer.
CHECK PRICE
Pros:
  • It prevents glares and reflections
  • Highlights are impressive in HDR content.
  • Quick response time
  • Great contrast ratio
Cons:
  • No special gaming features
5. Overall Best TV for Bright Rooms: Samsung Q80/Q80T QLED
The Samsung Q80/Q80T QLED is one of the best-LED TVs on the market for bright rooms.
The Samsung Q80/Q80T QLED is a 4k TV that includes Samsung’s “Ultra Viewing Angle” layer giving it better viewing angles than the above TVs’ VA panels.
3093413
The real selling point on this TV is how good it performs in bright environments. It has a high peak brightness allowing you to see crisp detail even in sunny rooms, and handles reflection exceptionally well. The wide color gamut makes the screen incredibly bright in HDR allow highlights to pop and get the most out of your TV.
Much like the previous TV, it has no problem upscaling lower resolution content from DVDs or cable boxes.
CHECK PRICE
Pros:
  • Great viewing angles
  • Performs well in bright rooms
  • No calibration necessary
  • Can be wall-mounted or displayed on a stand
  • Converts low-resolution content
  • Good for gaming
Cons:
  • Lower contrast ratio
  • Uniformity issues
The Bottom Line
Overly reflective screens and frustrating seating angles are a thing of the past with these LED TV’s. It’s impossible to find the perfect TV for your bright room. However, with these LED TVs, you can get pretty close. The important thing is to measure each device’s pros and cons and decide which TV will work the best for your bright room.
As an Amazon associate, we earn from qualifying purchases. We are committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works here.
Cover image from shutterstock.com
