Status
Not open for further replies.
1 - 3 of 3 Posts
I have a Panasonic 42 plasma and i need a tuner for the cable tv which is a poor analogue signal. I jsut bought a sharpVC-SH1000W...but then i was told that i should get S-VHS??
Advice please (before I open the box!)
sk123,
In general, the s-video output from an S-VHS VCR will look better than the composite output of a standard VHS VCR. You might want to consider a JVC HR-S7x00U or HR-S9x00U, for example. ("x" increases from year to year; I'm not sure if they use the same model numbers in the HK market.) The 7000 and 9000 series include a full frame digital time base corrector and a 3D comb filter, which results in a very stable image with accurate colors.
I hope this helps a little.
SK, get a JVC 9600 or 9800 VCR. They have the anti-ghousting tuner. The anti-ghousting circuit can be turned on and off. The anti-G circuit helps bring out the best pssible from my very poor Crumcast Cable service. Plasma tends to show every defect. I'd get JVC's best. Best wishes!
1 - 3 of 3 Posts
Status
