Status
Not open for further replies.
1 - 7 of 7 Posts
I hope I'm not starting a religious war by posting this question. :)
I'm connecting an HTPC to a Sony 1272Q (ceiling mounted), and I estimate I'll need a 25-35 foot run of video cable. I'm willing to spend the extra dough if it produces a meaningful improvement in PQ, but I always love a bargain. I've asked a friend for suggestions, but I thought I'd tap into the wisdom here as well...
What do you use / recommend for a budget solution with great results?
Would like to keep this under $100 if possible, to give you an idea of "budget," but that is not firm.
Johng316
Just started looking into these as well.
Markertek has a 25' double shielded HD15 to 5 BNC cable for $82.99. They will do custom cables in greater lengths too.
Shawn
I would also recommend avcable.com. I purchased a 16' RCA-BNC and a 3' VGA-BNC and the cables are top notch and not outrageously expensive.
Discussion Starter · #6 ·
Hey,
The one in the auction looks identical to the cables at PCcables but it's more expensive (twice the price.) And you have to deal with ebay instead of a real store.
Here's a direct link to a 25' cable for comparasion you will see the cables are identical. Note: I would link the 35' cable but the pic on that page seems broken.
http://www.pccables.com/cgi-bin/orde...les.com&rcode=
This is the route I went and I'm satisfied. Someday I may do the right thing and buy bettercables though.
Good Luck,
Brian
1 - 7 of 7 Posts
Status
