1 - 3 of 3 Posts
Im planning on buying the TC-P42G25 and have looked around at all the wall mounts and cannot narrow it down. Im very picky and I like to eliminate everything until theres just one perfect item. I do not want to spend over 200 dollars but I also dont want to buy a cheap mount that I will regret in the future. Heres my current situation
-needs a swivel (45 degree rotation should be good enough)and tilt (just a little tilt if any)
-42 inch
-the wall im putting it on is between a sliding glass door and window so the width of the mount on the wall must be less than 24 inches
-id like a price range between $100-200
-Any tips such as well known and popular manufactures is much appreciated =]
always check monoprice.com first.. they might have something that fits the bill
1 - 3 of 3 Posts
