Status
Not open for further replies.
1 - 2 of 2 Posts
I've looked all over this forum and haven't really found an answer to my problem. Any help would be greatly appreciated.
I need some help on getting a new multiswitch. I currently
have a a oval dish with 3 lnb's 101, 110 & 119, otherwise known as the sat-c upgrade. They are connected to the 2x4 multiswitch that came with the Terk dish. I have 2 tivo's which are currently using up all 4 of the outpus. I just purchased a HDTV receiver and need another output. I've seen some stuff that allows you to split the signal somehow before it goes into the Tivo but all of the articles are for dual LNB's only.
My question is, can I simply buy another 6 or 8 output multiswitch and somehow cascade it with the current 2x4 or is there a way to split one of the current signals that already runs into the house? I know you can't use a normal splitter. Also whatever option is used it must work with the new Sat-C kit (3rd LNB) I just installed. I've looked at the Spauns (expensive), Channel Master, Trunkline and Eagle something or other.
BE
1 - 2 of 2 Posts
Status
