Status
Not open for further replies.
1 - 4 of 4 Posts
LJG,
That depends on your other HD equipment and what outputs they have. The JVC 30k has HD component outputs that can output 480i, 480p, 720p or 1080i depending on source material and menu settings.
The most cost effective method would be to have all equipment use their component outputs so you would only have to run a three coax cable from a switch box to the projector.
If you have to mix RGBHV and component then things get messy and expensive.
Good Luck, Don
Premium Member
Discussion Starter · #3 ·
I have a NRS plus connected to projector via RGBHV, the NRS also has a HD pass thru( VGA pass-thru), and I am running my Sony HD100 1080i signal directly to the projector with a VGA to RGBHV breakout cable to input 3 of the projector.
What a dilema. :)
I am going to buy one of these soon. Are the G90 and the G70 similar as far as inputs go? I have a MSB mod DVD tying up the RGBHV input and was wondering how to hook up the JVC 3K when I get it also.
thanks.
MRW
1 - 4 of 4 Posts
Status
